Can't edit /boot/emonhub.conf Writing not enabled
I have modified this file in the past by following the instructions on https://github.com/emoncms/emoncms/blob/bufferedwrite/docs/setup.md, but just doesn't want to do it this time. The system is running in local mode.
I ran rpi-rw, then nano /boot/emonhub.conf, nano reports that it can't write.
I thought may be the file was locked by localemons running so I then tried localemoncms-disable and repeated the steps above, but no luck.
I think I must be missing something very basic here. Any ideas?
malonsorosa's picture
Re: Can't edit /boot/emonhub.conf Writing not enabled
Have you tried
sudo nano /boot/emonhub.conf
craigfryer's picture
Sorry, I resolved the problem. Thank you for your help.
Craig,
What was it that resolved your issue?
A reboot, but that alone shouldn't have been the reason.
