Emoncms mqtt as input
I see from the "Extended" branch of emoncms on github that "Input data into emoncms via MQTT" is supported.
I installed emoncms from the extended branch but dont see any mechanism to configure inputs with mqtt.
I enabled  mqtt in settings.php [cant remember the exact config name] but dont see anything apart from the conventional json inputs.
Can anyone help or direct me in the right direction.
Jason
Re: Emoncms mqtt as input
Hi Jason, MQTT has still not been properly integrated into emoncms(unfortunatly)
Hopefully soon!
allmac's picture
I send MQTT data from many different equipments to my Emonhub, and they are logged into Emonhub NODES.
Is there not any way to send (received data) also to Emonhub INPUT?
!! WHY MQTT? I use my Emonhub server Mqtt Broker to get same data into my Openhab server.
