Problem with Electricity Consumption Meter Sketch (TinyTX)
I am using this sketch to read LED infrared pulses on my electricity meter.
The sketchs is uploaded to a TinyTX (Attiny84A-PU) and sends current Watt consumption to my raspberry pi using RFM12Pi from the OpenEnergyMonitor Shop.
https://github.com/nathanchantrell/TinyTX/blob/master/TinyTX_LDR_Meter/T...
Everything works fine, but...
If I use a higher send interval (please see line 33) above 30 seconds, it stops sending!
Maybe a problem with the sketch? Can anyone help?
Best regards,
Christian
Re: Problem with Electricity Consumption Meter Sketch (TinyTX)
I see your problem. There is an error in the sketch (or an assumption that you will not want a delay greater the 32.767 s).
sendInterval is a signed integer, therefore 1000 * sendInterval overflows at 32767.
If you declare sendInterval as an unsigned long, or change "1000" to "1000L" the problem should go away (until you ask for a delay of a few weeks!).
You should inform Nathan Chantrell of the error.
pfeilc's picture
Hi Robert,
great - thank you very much!!! :-)
I will change my code and also inform Nathan Chantrell of the error.
Best regards,
Christian
