emonHub command line options
I've put together a small script to make using emonhub conf and log files easier to use and automate upgrading emonhub from git. It's work in progress so don't expect too much.
Hopefully in time this stuff will be integral to emonHub or at least its installer but for now this should do ok.
I'm hoping it will be included in the next pre-built SD card but if you have an existing set-up SD or HDD this script will instal just the emonHub command line options file. to instal run (if running read-only use rpi-rw 1st )
wget http://openenergymonitor.org/emon/sites/default/files/emonhub_utilities_... -O ~/hub_utils.sh
chmod +x ~/hub_utils.sh && ~/hub_utils.sh
The emonhub command can be used with any of these valid options
        emonHub utilities
           -c  or --config        Opens the configuration file (emonhub.conf) for editing
           -h  or --help          Displays this help for emonHub utilities command options
           -r  or --restart       Restarts the emonhub service
           -s  or --start          Starts the emonhub service
           -u  or --update      Updates emonhub from the git repository (git pull)
           -v  or --version      Displays the emonHub version installed
           -x  or --exit           Exits emonHub by stopping the emonhub service
        emonHub logging
           -dl or --display-log   Display last 10 log messages and continue to monitor logging
           -ol or --open-logfile  Open logfile with "nano" text editor
           -rl or --reset-logfile  Reset the current logfile (deletes any existing log messages!)
           -vl or --view-logfile  View the entire logfile using "cat"
If running a RO image any instances that require RW mode will take care of that so any of these commands can be used whilst still in RO mode, also without sudo​ annd if the file system was RO prior to the command it will be returned to RO. So if rpi-rw is used prior to a command it will not return to RO mode.
EDIT - Changed the attached file as the file was saved on a windows machine which upset linux. should be ok now. but please let me know if not
