Emoncms.org Datapoint editor
Is the Datapoint editor working in visulisations on emoncms.org?
I can't get it to edit any points?
Re: Emoncms.org Datapoint editor
As far as I'm aware, no it isn't working at this time.
rmtucker's picture
Has it been removed for some reason.
I get the odd spike now and again and can not find a way of editing them?
Mark
It was removed because it did not work with phpfiwa feed data.
I'm not aware of anyway to edit datapoints currently in emoncms.org.
The "editdaily" and "editrealtime" functions in Vis were disabled  on emoncms.org, but they are now functional again, however you cannot edit PHPfiwa datapoints even though the option is there and it goes through the motions, the edit doesn't appear to be saved.
Bruno's picture
Am I right to assume this isn't working in local installations? I mean, for PHPfiwa.
​I tryed to delete a spike without success.
