Posting locally and to emoncms.org?
I've read the guide (https://github.com/emoncms/emoncms/blob/bufferedwrite/docs/setup.md)  but as a beginner I still need to know exactly what to write when I want to post locally and forward to emoncms.org.
Re: Posting locally and to emoncms.org?
In emonhub.conf you will need to create a second reporter, you currently have something along the lines of
[[emonCMS]]
      Type = EmonHubEmoncmsReporter
      ​[[[init_settings]]]
      [[[runtimesettings]]]
            url = http://emoncms.org
            apikey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
so below that add something like​
[[Another_emonCMS]]
"Another_emonCMS" can be any unique name, localhost can be an IP address or URL (sometimes localhost doesn't resolve on some servers) and the apikeys will of course be specific to each emonCMS too.
eugen66's picture
Thank you very much for the quick reply ;)
Dafroberts's picture
I'm trying to do the same but cannot get the above script to work, I get the following error message in the log
2015-01-30 18:58:56,048 WARNING Could not get settings: Error parsing config file: Invalid line at line "42".
2015-01-30 18:59:06,960 CRITICAL Error parsing config file "/boot/emonhub.conf": Invalid line at line "42".
2015-01-30 18:59:26,525 CRITICAL Error parsing config file "/boot/emonhub.conf": Invalid line at line "42".
2015-01-30 18:59:56,400 CRITICAL Error parsing config file "/boot/emonhub.conf": Invalid line at line "42".
Any ideas what am I doing wrong??
Dafydd
Hi, There is an error reported with line 42 of the emonhub.conf. Check over the edits you made, can you post a copy of your conf?
​Paul
